I wanted to overclock my processor a bit, and I got thermalfusion 400 applied it and started my system. I am getting 50 degree at idle and goes beyond 75 with prime 95. Should I remove the heatsink and reapply it again? What's the correct way to apply thermal paste to core i7? Is thermalfusion 400 good enough? I live in Hyderabad(India), and no other thermal paste is available in my city. I need to get it from another city which would take 15-20 days. If not thermalfusion which one should I prefer? IC diamond carat 7 and ocz freezer look good to me. I might also apply some to my IOH chip. MSI eclipse runs hot at 65 degree currently
Since it's only 25 degrees difference with Prime it is OK, you shouldn't worry. Maybe the back of your case needs better ventilation.
Don't use Arctic silver 5 ! It's electrically conductive and takes 200 heat cycles for silver particles to be totally effective. It's just old tech, messy, no sincerely it was great years ago. And MX2 has close performance if not better, and much safer. It is also stable over years, what most thermal pastes aren't.
. I have good ventilation, did proper cable management and with HAF 932, airflow shouln't be a problem. I would try arctic as many of you suggested, and would get a better cooler in future.
