- Feb 24, 2009
I am looking for some input on the core i7 temps when overclocking. Currently I have an i7 920 with a thermal take V1 copper cooler, with a 110 mm fan at 2150 rpm. Now I have my i7 at 3521 Mhz with a idle voltage of 1.208 and a load of 1.218, or I should say in BIOS it is +0.03 on top of 1.192 default. My QPI is also +0.03. My Dram is 1.55, and that is all I have changed. But my temps when running LInx, with 4.4 Gigs of Ram doing a 20,000+ size problem (like 24000 mainly) I get temps under load of 83 81 79 78. Which for me I do not like. Now I know linX really pushes them temps but I think they are high. Could it be the amount of Ram I am using or does that matter, or the problem size? I ran it for like 2 hours and get a max of 83, it stays like 81-83 on that core when loaded. I am worried that it is too warm. Now the stupid [***CENSORED***] I am put my CPU fan on backwards, so it pushes into the case and not towards the rear fan. But I turned the rear fan to push air into cpu fan and then out the case, the front of case it all mesh air filters with holes in drive bays. I have a thermal take armor+ full atx case. I have the bottom fan now pulling air out the front, so a backwards S what have you. I also have a 230mm windows fan at like 900 rpm pushing on my GPU. My hd 4850x2 does not have a built in fan that blows air out the case, its exhaust blows on the windowed fan (since it is lined up there) but it is basically going into the case, and it runs hot, like 45 C when idling. Now my rear fan is like 1500rpm a 120mm pushing and my front is a 1200rpm 140mm pulling. I amtyring to get more fans, but if I do I do not know where to put them. I also am trying to get some arctic silver cleaner to clean CPU and switch cpu fan. I think my CPU fan is screwing this all up. My IOH is like 127 C and I am just worried about pushing my cpu anymore or am I pushing iot too far under these conditions. I does not blue screen under load now and runs good. But for 24/7 use, not under load , is is a good idea to keep it or under clock a little until I get more airflow. Give me some input please!
