Coreliquid consideration for 13900k
Hythosdb
I've seen the available specs provided via https://storage-asset.msi.com/datasheet/liquid-cooling/us/MEG-CORELIQUID-S360.pdf and other Coreliquid-line of products...
however I haven't seen anything anywhere of the anticipated BTU / thermal transfer capabilities.
The "fins per inch" is not listed, but can be approximated if any of the product images are accurate.
Having a GPU & CPU (and potentially HD's, SSD's, RAM) - pumping into the system, 1000w (on the higher end) of thermal absorption wouldn't be unreasonable...
As for the Meg Coreliquid S360, what amount of wattage should this be capable of handling? The 13900k is already 350w (expected) not considering OC'ing...
Also...
What is the difference between a MAG P360 and MEG S360? Performance difference? I don't see a whole lot on the spec-sheets (though I can look again) to warrant a 2x price.
I can only go buy what I have, and I have one of the MAG CORELIQUID P240
It could easily keep my AMD R9 5900X doing a full Stress test with Aida 64 and Cineabench 20-minute test runs under 85c
Full core load at 4600Mhz pulling just over 210 watts on the Package
With Air Cooler I was getting throttle but not with the AIO I would say the Cold plates are quite effective at heat removal as overheating I never had a problem when using the AIO. The AIO was mounted top of the case and has 2 140mm Bequit case fans front mounted for intake
Also running a AMD RX 6900XT or a AMD RX 6800 at the time of testing.
Also...
S360 has a Pump in the Block and an LCD screen that will show Temp and some other stuff.
The P360 Has a pump in Radiator and no LCD screen or RGB rubbish
I'm using an S280 just because I want quieter fans and the difference is not worth the S360....
Overclocking a 13900k to 6GHz and temps are around 96C and it's very quiet under medium load... I just wish it can display the GPU temp but what do you know...
