Coreliquid cooler connectors
Hythosdb
Do the Coreliquid coolers use the G14 / G1/4 thread? Something else standard?
Would it be possible to "open" the system and add-in something to the loop? Or would it be impractical to try to seal up the circuit.
Hi
It's a fully sealed AIO. Nothing to take apart here, unless you like voiding warranty and possibly killing the unit.
Thanks Nichrome - Originally I was thinking I could use the radiator and pump from my P360 and connect to, though I was able to make a P360 fit where I needed.
I think EKWB sells this kind of AIO that is customisable. But at this point it's better to go fully custom loop. Enjoy :)
