CORELIQUID MPG K240 CPU Cooler Hardware damaging programing issue!
arbysseus
Yesterday support provided me a new version of MSI center 1.0.33 and so far it has been stable. No cooler temp hangs, no memory leaks, stable RGB. It looks like these issues are finally fixed.
shanewymor155b02d7
Version 1.0.33 is solid so far, hours of sitting at idle while I work and I just checked my gaming rig. MSI Central Server is only utilizing around 22Mb after hours of running, I have been listening to the fans ramp up and down here and there, the readouts on the screen are accurate. The last version had a terrible Memory Leak, 3 hours would go by and utilization would be at 1.8GB and climbing so, I am extremely happy right now. MSI Central Standalone 1.0.33 is definitely the way to go
shanewymor155b02d7
Just letting everyone know that I have tested version 1.0.33 for 48 Hours, leaving my rig on the entire time. Everything works solid and there is nothing to worry about. With the previous version or version or version from the Microsoft Store, I was having all kinds of issues from Memory Leak to Custom Fan Curves not working after 3 hours. This is definitely one of the better AIOs on the market, highly recommend dialing the top end RPM down on the fans though, sounds like you're sitting in a server room when they hit 2500RPM lol!!!
Cearbhall815ba02e4
I am experiencing issues with the new release, 1.0.36. I have no display on my pump face after windows uses winusb.inf config, to assign the driver usbwin.sys to my JUSB device. labelling it MPG CORELIQUID and then display goes blank. Seems like driver issue overriding the JUSB1 port that runs the display part of the datalink. anyone else have their displays not function after windows launches??.. I can get the screen to work if I shut down after disabling and uninstalling the assigned Driver. but then windows automatically reinstalls it. Windows 10
shanewymor155b02d7
I am pretty ticked off at this time, my 1.0.33 version keeps auto updating (even though I have Updates disabled) and the new version 1.0.36.0 from the MSI Site crashes every time I try to access the Core Liquid settings. @MSI User what is going on here, you should've left it alone. Now, every day I have to uninstall and reinstall 1.0.33
