doruc158f02e0
- Oct 11, 2024
I got an MPG D360 AIO replacing a MAG S360 to get more cooling for my 14700.
When I set the fans on Silent the fans are still turning at 550rpm. That was not the case with S360 cooler that was stopping the fans. If I use the fans from D360 on S360 they are stopped, so it is not the fans.
I have a similar issue with the water block fan still turning at 1027rpm.
I checked the temps on cooler display, MSI Center, and on HWinfo and they are around 35C. MSI Center shows that in Silent mode fans should be off when temp is under 50C.
The pump is turning at 1764rpm, and that might be fine (50% of 2800rpm+/-300rpm).
Any ideas?
I'm running latest software:
MSI Center 2.0.42.0
Coreliquid 3.0.0.73
BIOS A80 on MAG Z790 TOMAHAWK MAX WIFI
Any ideas?
MSI Center 2.0.42.0
Coreliquid 3.0.0.73
