Coreliquid P13 issue
Hi!
I just installed my MSI mpg coreliquid p13 360 AIO cooler.
1st boot after installation showed the LCD turning on, but after showing the logo. it doesnt do anything anymore.
I wanted to check the MSI Center to see if there are updates that need to be performed, but the application is soooo slow.
When I click "open" on the Coreliquid application, it just keeps loading and loading.
Re-opening the application, re-installing the Coreliquid app and restarting my PC doesnt help.
Also, the Screen is not recognized as a 2nd display inside Windows settings?
Any help would be appreciated as I have no clue whether the AIO is actually doing something
I was finally able to scan for new updates, but none are found.
My AIO cooler is not listed in the MSI Center while everything is connected properly.
Based on the fact that on the 1st boot the screen lit up and the water started running I presume verything should work right?
Screen even lights up again showig the logo if I turn off my PC, draw all remaining power from it and then restart the PC
Any ideas?
Click on "Coreliquid" and you can customize it to show hardware monitor, clock...etc, or do you mean it still keeps loading and it won't open?
Are you using the latest MSI Center 2.0.63.0?
I just got my Display to work hesterday evening!
It just works but i cannot customize it in MSI Center yet.
Its not being picked up, even though i have folder in MSI Center > Coreliquid > P13.
Whenever I click ‘open’ on the Coreliquid feauture, it just keeps spinning the loading icon… i can leave it spinning for hours without anything happening.
I can only enter the feature maybe 1 out of 5 times, but then it just displays nothing with a scan button for updates (which there are none)
Hello!
This morning my LCD started showing all correct values for my CPU, memory, GPU...
I ran MSI center as administrator and somehow now I was able to open the coreliquid feature with no loading time at all!
I can now adjust and change the display to my preference.
I think my issue is solved :)
That's great!
Maybe something is updated in the background? Have you checked Windows Update history?
No… nothing in the update history hints towards any drivers for the P13 or any other component of my PC that could be causing the issue.
Im just very happy that it all works now! Such a nice AIO cooler now hahaha
Thanks for all the help and suggestions!
Im running into precisely the same issues as described above. I guess my only hope is that it magically registers and works as well?? I tried running the firmware updater and the moment I launch it it just sits there and spins perpetually.
I too have tried to reinstall/repair/reset msi center.
Interestingly my dynamic dashboard plugin also stopped working and gets stuck in a perpetual load after installing this AIO cooler. Wonder if there’s a link? It’s been working flawlessly for weeks now.
Just as OP mine magically began working randomly after more reboots. To be clear for any future people finding this thread - I repeatedly shut down prior to it working. Why exactly it began to work I genuinely don’t know. The only thing I did differently was that I poked around in the BIOS for any possible leads. I found none and made no changes whatsoever. Gave it one more reboot and was up and running. Best of luck to anyone else running into this. It’s bizarre.
and after a restart / newstart , dit it apply the changes u make , backround, cpu temp , usage, gpu temp etc , mine is only holding the backround i chosse and cpu temp , everything else i have to redo every start
