coreliquid S360 screws (J) not fitting AM5 backplate B650 tomahawk
f.kalscheue12c202ae
just try to mount the cooling block on the AM5 backplate from B650 tomahawk. But the distance scews (J) not fitting because the 6.1 mm side is to big. The 9mm side is ok, but backplate as the mounting screws (K) are bouth only fit the thinner diameter. There are more distance screws (I and H) in the package with both sides perfect diameter but they are meant for intel and little longer.
What to do now? Can ii use the longer distance srews or not?
Please help
