Hi, my problem was caused when during a bios update, my PC turned off causing a bios error. After that, I tried to reset the Bios by removing the battery and doing a CMOS Reset, but when I did it, the PC started only turning on the CPU LED and without showing any signs of doing anything else.
It should be noted that I have two processors, the one I was using during the update (AMD Apu A8-9600) which I was using to test some things, and my main CPU (AMD Ryzen 3 4100). I was doing this update so that the BIOS is compatible with this processor.
I don't know what I should do, on one occasion I used Blind Flash for another case, but I think it won't work due to the processor problem.
MB: MSI A320M-Pro-VH-PLUS (7B07)
