CPU temperature sensor freezes on MSI X870E Tomahawk WIFI
ilya.mfw12e402b7
Hi, I'm another owner of a motherboard with a stuck sensor
I will not write the details, as everything has already been described on this forum and Reddit:
https://forum-en.msi.com/index.php?threads/msi-x870e-tomahawk-cpu-temp-sensor-gets-stuck.413221/https://forum-en.msi.com/index.php?...k-properly-when-the-temperature-rises.411247/https://forum-en.msi.com/index.php?threads/9950x3d-sensors-stuck-mag-x870e-tomahawk-wifi.413098/https://www.reddit.com/r/MSI_Gaming/comments/1hejqx3/mag_x870_tomahawk_wifi_lan_issues_fix/https://www.reddit.com/r/AMDHelp/comments/1kt1mat/ryzen_9950x3d_sensors_stuck_under_load/
System:
MSI X870E TOMAHAWK WIFI
AMD 9950x3D
Arctic Liquid Freezer III 420
PCCooler YS1200
GeForce RTX 5070 Ti
If you have solved the problem with the sensor, please share the solution in this topic
Your comment is on point, this has nothing to do with monitoring software, since it will break on every single one of them, ryzen master, occt, afterburner, any
Im currently testing some custom bios they are sending me, no success so far, if anything solves the issue, i will post it here
Your board was not on warranty? im trying to fix this but i have the option to send it to my local msi representation and get a refund, but im trying to avoid the massive headache, plus if they manage to fix this with bios updates, will help everybody
The board has warranty, hence MSI said they would repair it, but I have to pay my own shipping to get the board to them first.
I'm also on A70, as I tried the 2 of the 3 pre bios and it causes a conflict with a pcie hba card I have. I go from a 10second post to a literal 2 minute post. If I remove the pcie card, then I get 5 second posts. But I need this card, and 2 min boot times when I have to constantly reboot from stuck sensors, is not a fun proposition.
Your board is a X870 or X870E?
I tried 2 custom bios they sent me, so far no success, reported the last one and they are checkingg
Sorry, I'm on an X870 Tomahawk. I just tried the latest firmware, same problem. 2 minute post time stuck in A0 debug, and then when posts, BIOS doesnt see my PCIe card. I humored them and proceeded to windows. Ran Aida64 stress test and cpu sensors froze after 4 and a half minutes. So no fix for the sensors, and still a conflict with my pcie card.
I was able to confirm the CPU Package Power in Hwinfo64 hits 0 when it freezes. So I set an alert in Hwinfo64 and to write a log when it happens so I can see mid gaming when it happens, as I only noticed after a session when the temps didnt come down.
Just want to document that it's been happening to me again, this time at seemingly lower temps than before.
My max temp on my 9800x3D was 80.2 - it froze reporting at 70.8C though. Normally when it's froze for me it's been during a spike in the 80s.
Hello guys!
I am the proud owner of this problem. (board is a X870, processor is a 9950X)
I'm trying to solve it by adjusting the BIOS settings.
1. C-State = disabled (So that the processor cores are not disabled)
2. PBO = advanced
3. PPT = 180 W
4. TDC = 110 A
5. EDC - 150 A
I ran test CPU on the AIDA 64 for over an hour and the temperature didn't freeze, the power didn't drop to 0. Frequency = 5.2 GHz.
Then I ran a 3D Max rendering test for over two hours. Temperature and performance were fine. With my settings, the CPU temperature never exceeded 65 С.
I don't play games and can't test my assumptions in games. Could you take my settings and use them for testing?
Hello guys!
2. PBO = advanced
3. PPT = 180 W
4. TDC = 110 A
5. EDC - 150 A
Turn off the PC and try again, there are some boots where the bug never occurs.
You tuned my parameters for BIOS and got an average temperature of 90 degrees?
I used test CPU from AIDA 64 and temperature didn't up above 67 C. (I use 9950X)
These is my test, but Russian language.
No, with your settings I had values similar to yours, but the bug still occurred. Now I'm trying more aggressive settings. In one hour of testing it hasn't happened yet, but I need to run more tests.
