CR52-A2 CD-RW (track following error???)
N
necrobied
Guest
I have a 52x24x52x, burn some discs and now y get TRACK FOLLOWING ERROR every time i tried to burn, what is it????
I use nero and, i see the possible problems, but nothings happen.
Somebody knows the problem.
J
jazzing
Guest
Are you using the latest firmware 180D? If not, try that first.
Otherwise it's probably the 180D firmware that's the problem. When I flashed to it, the drive refused to read my CD-RWs any more (Verbatim 16-24x / Fujufilm 4x), even though 180D's meant to increase CD-RW compatibility. Had to flash back down to 161D to fix the problem.
Can get firmware here
h**p://forum.rpc1.org/dl_firmware.php?category=6&manufactor=21
N
necrobied
Guest
I use the latest firmware version (180D) and the problem appears, then i go back to firmware 161D and i cannot burn disks, the message -following trak error- still appears, this no solve the problem.
What can i do??
