kickasskingy
- Jan 20, 2021
Good Day All,
I have been having some issues with the onboard sound and I wanted to post here before taking it to MSI Support as they will likely request I send the mobo off.
I have unfortunately been having issues with crackling/squealing sounds on both onboard and rear I/O audio ports when the PC is under load. I can even hear the mouse move across the screen!
My system:
MSI MPG X570 Gaming Plus mobo (BIOS 7C37vAC3(Beta))
Ryzen 7 X5800
2x8G Corsair Vengence RGB PRO DDR4 3600 (CMW16GX4M2Z3600C18)
PNY 3060 Ti XLR8 Epic-X
I have googled this extensively and people are suggesting that it is an issue with BIOS rather than a faulty mobo. However, I tried everything and failed to find a solution thus far. I have tried:
- Unplugging the front audio header.
- Cleaning and reinstalling the audio drivers from the MSI website.
- Adjusting the VDDG voltages between 1-1.1V ( https://www.reddit.com/r/MSI_Gaming/comments/el6e8m )
- Downgrading the PCIe to Gen 3.0
- Removing XMP and defaulting RAM (few forum comments suggested it as a fix)
I am currently using the audio through my GFX card and monitor, but it means I cannot use my headset too well.
I am at a loss, has anyone else experienced these issues and had a fix?
All the best
My system:
Ryzen 7 X5800
All the best
