Hello guys.
I have Unify X, 12900K, 6000Mhz DDR5, and i have 5 m.2, x2 2tb EVO Plus, x1 2tb XS70 Gen 4.0 [the only gen 4.0 i have], x1 2TB MP510, x1 U.2 4TB Intel Enterprise Drive connected with cable to M.2
I have no GPU in the first slot i use a riser so GPU is vertial and doeant heat up anything
but in second slot i have Intel Optane 480gb
I found 2 issues.
#1 Both M.2 drives that conencted across the chipset run HOT, i have them in the biggest heatsinks, is thoise black tall 3 heatpipe heatsink and they IDLE at 48-50 [becuase of the chipset]
#2 chipset Idleas at 70 with Power saving turned on [on auto, will change manually and see how it runs]
I found a solution and i recommend it to everybody its not that ugly and its the only solution that we can just install, easily,without losing speed and performance.
With one of my otehr PC, ASUS board i received a metal fan bracket that screws into one of the motherboard standoff screws that hold the board it can hold a small fan, i think 40mm and 50mm, right now i installed it for the VRM [im on custom loop and have no air flow]
But im going to move it and buy another one, here is a link on aliexpress its like 2USD, BUT don't buy their fan, get a noctua fan
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
Also i recommend to swap the heatsink thermal pad, its up to you but if you want a recommendation for good one let me now, these are like paste but they thermal pads you put them on screw the heatsink and they squize and form just the right size, i use this "paste" everywhere now [its not a paste but Thermal pad replacement, Linus Tech tips had a video about it, sold on amazon].
If you afraid and think it might void the warrnaty, at least Tighten up the screws that hold the heatsink
If you want a better solution, here is a Copper universal chipset heatsink with fan, its chinese so replace the fan with Noctua, it should be smallest and least visible solution
www.aliexpress.com
