Creator 17 A10SF - WiFi problem
Hello. My Intel 10th gen Creator 17 has a very serious problem with WiFi. No matter what, the WiFi card does not work. I can't turn it on in any way. I have already uninstalled and cleaned the drivers using Device Manager and reinstalled both the drivers from MSI and those from Intel. The error is something like "This device cannot start. Code 10".
The system now runs Windows 11, but the issue was present also in Windows 10.
Any advice? Thank you.
drek4
PRIVATE FIRST CLASS
View attachment 152627View attachment 152628
If you uninstalled the dirivers and did a clean install with the latest drivers from Intel, then return if under warranty or purchase another wireless card.
Hethdra_0328
Try uninstalling the Network device a few times without checking the Remove Software Driver box.
