Creator 17 default system memory
Hi guys,
I planned to buy a Creator 17 but i didn't find this information, I need at least 32GB ram but the manual report only this info:
Up to DDR4-3200 Memory Type
2 Slots Number of SO-DIMM Slot
Max 64GB Max Capacity
thanks in advances
badboy2k
lowest version has 16GB of RAM that is sold with 2 8GB modules there are ones with 2 16GB modules if more expensive and the top of the range have 2 32GB modules it just depends on the model you buy as it Varies from exact model to model to what the actual specs are!
where in the world are you and how much did you plan to spend on one?
