Creator MSI Harddisk Health %0 Issue
Hello there, I just got a MSI Creator A10 SET and although I didn't face any problems with harddisk so far, its Hard Disk Sentinel results were quite worrying. It said health faileure predicted %0. Is it normal? Why do I have this problem?
badboy2k
that Utility is designed for Mechanical Drives not SSD's its common for that utility to not be able to read the drives controller properly so gives the Failure Predicted message. its just the software not being able to talk to the disks controller correctly.
so you feel better go to the forum for that software here https://www.hdsentinel.com/forum/viewforum.php?f=3 and ask them about it but i can say with 99.9% certainty its a false Report its giving
So, do you reccommend any other utility app to check whether the hd is problematic? Because the techician says it would be really problematic in the future and I have 2 years warranty.
No, I don't have any problems with SSD. I am even not sure if HDD test is proper for my device Creator A10SET. Some people told it didn't have HDD but SSD instead. Is it the case?
Crazydonkey
SECOND LIEUTENANT
This software is also suitable for SSD, so you can use it to check your SSD status.
And if there is no problem with the SSD, I think you don't need to worry about the error, it may be related to the testing software problem.
