Cube reliability
bshop47155602da
Looking at CubiNUC 1MG-007US, for multi task and office use, no gaming. Just had a geekom cube go dead after 18 months, so now looking at reliable units. Like the testing that MSI does. Is the cube reliability the same as the Pro DP reliability, or does the smaller factor contribute to shorter lifetime or less reliability due to smaller space, different components, potentially more heat, etc?
It'll be running Windows, so it won't be extremely reliable in that regard.
But hardware-wise, it should do just fine. If you don't do anything stupid with it, it should serve you for years. Though be aware that this is still electronics, so it may fail any time.
Is a NUC in Disguise and I have had My NUC running since 2018 and it still going strong In that time I have done a Memory Upgrade from 16GB to 32GB and Upgrade to a bigger M.2 And occasionally blow out any dust
got 2 MSI Cubi's one is from 2016 and one from 2018 and neither of them has Failed so been Quite Reliable Indeed so far.
Thanks for the input Nichrome.
