CUBI N do not start
Hi everyone
My CUBI N do not start. What can be wrong?
Some information:
MSI Cubi N Mini-PCPentium N6000, 4 GB RAM, 128 GB SSD,
Have updated the RAM to 16GB Kingston and the HDD to a Samsung 500GB M2 SSD980
It was working fine and after it has been shut of for a few days it's dead, noting no led, no fan, nothing is working.
What I have tried:
Disconnect the CMOS battery for mor than 5 minutes
Changed power adapter
No change, it's still dead.
Can you try to boot with 1 memory stick only?
If you connect a watt meter to the wall's outlet and connect the Cubi's PSU there,
does it shows any power consumption?
But I don't have any watt meter. Have to see what I can do about that.
oks
Thank you for the reply.
I only have one memory stick.
Can you try another one, if possible from the QVL list?:
https://www.msi.com/Business-Productivity-PC/Cubi-N-JSL/support#recommend
Or if you still keep the original memory stick to swap back?
Thanks for the reply
I tried with original Memory and M2-SSD and two different PSU (Original and one noname with same voltage/Current spec). Nothing at all. Think I buy a watt meter asap.
Oks, if needs also disconnect any storages too before try to run it.
