CVNi Wi-fi Problems
redbarrontx
I am currently running the MPG z390 gaming plus MB, with Intel i7 9700. I have been trying to install the intel wifi 6 gig+ in the CVNi slot on the motherboard. Customer support said that the ax200 was not compatible and shared a link that shows compatible kits on the intel website. noted here: The AX200 is not a CNVi module, please refer to Intel site for the supported list https://www.intel.com/content/www/u...6155/network-and-i-o/wireless-networking.html
So I purchased the Intel® Wi-Fi 6 AX201. Well upon install the pc would not turn on with the chip in cvni slot. I removed the chip and it turned on as normal. Am I missing something in my MB configuration in order to get this thing to work. It is really frustrating.
zerijelly
FIRST LIEUTENANT
AX201 uses CNVio2 which is not compatible with CNVio interface. The comaptible CNVio Wifi modules are:
  • Intel® Wireless-AC 9560
  • Intel® Wireless-AC 9462
  • Intel® Wireless-AC 9461
