Daisy chain cable to gpu
johndukes7158402e3
Hi ,
Sorry if this has been answered before , but I know people’s opinion varies on this.
I just bought a msi mag a850l power supply , I have a amd 7700xt which has 2 connectors for power , the power supply comes with a Daisy chain cable to supply power to the gpu, is this ok to use or am I better using 2 separate cables.
The graphic card is not over locked and using msi afterburner is shows the wattage at 249w .
Thanks for any advice , I appreciate 2 cables would probably be better but the Daisy chain cable looks tidier in the building.
John
Hi ,
John
do you Mean a MSI MAG A850GL PCI-E 5?
Yes sorry predictive text on , it’s the MSI MAG A850GL PCIE5 , ATX 3.1 READY , PCIE5.1 READY.
its better to use 2 Separate Cables for Stability you may get away with a Single Daisy-chained one but your card is close to the Upper Limit of what that can Handle.
you can give it a try and see how it goes but if you get any Crashing then go to 2 separate Cables.
Thanks for reply , previously it was running a Corsair cv 650 power supply with Daisy chain cable for the last 12 months , but thought 650w was a bit low so upgraded to this msi 850 , it ran fine for the last 12 months on the Daisy chain with the Corsair , but so many people recommend the 2 cables.
Thanks again.
Thanks again.
it should work with one but its Borderline. it should be able to handle it its just very Close to the Limit.
usually where all Individual ones are a must is if lets say its a Card that pulls like over 260W then its a you need to use 2 and mainly with NVIDIA Cards as they tend to have massive short Spikes of power Draw where it may be using for 99.99% of the time 240 watts but out of nowhere it will suddenly pull 300+ Watts of power and can make a PSU trip out and go into a Panic and cut all power as it thinks its gone Short Circuit and trips the OCP (Over Current Protection).
