- Feb 25, 2009
I have a bare-bones AE2020 AIO (AA1511-001US). Like most AIO PC boxes, the AE2020 has some monitor inputs and monitor controls - but how exactly do these work? I did try the experiment with the AIO running where I connected a laptop VGA out to the VGA in and used the monitor control buttons to select VGA and the laptop screen showed up just fine on the AIO screen with the expected Plug-and-Play beeps along the way. I also tried connecting my Panasonic HD camcorder to the HDMI input with no reaction at all - nada. I have connected this same camcorder with the same HDMI cable to one of our HDTV sets with HDMI and that works great. Another thing that puzzles me is the full functionality of the monitor power button. With the AIO running, pressing the monitor power button will turn off the AIO screen, and pressing it again will turn it back on, but nothing else.
So what else should that monitor power button do? According to Eddy at MSI technical support, the AIO monitor is supposed to be able to act as a stand-alone monitor with the main system power off. I had him repeat that statement in more detail. He said that I should be able to plug the AIO power cable in and press the monitor power button, and the monitor only will come on and it will display whichever input, VGA or HDMI, I select. This does not work. With the main system power off, the monitor controls, including monitor power, do nothing.
So how does your MSI AIO work? Can you use the monitor as a stand-alone monitor with the main system power off? Can you display the 1080i output from an HD camcorder at all? Can you display anything through the HDMI input?
Bye.
Bye.
