M1904
- Dec 5, 2021
So this afternoon I performed surgery to replace my failing/defective AIO. After getting everything back together and without buttoning it up I fired it up and we sat in POST with EZ Debug punching up against the DRAM LED pretty aggressively I might add.
cleared CMOS and when it didn't boot i knew i had a problem. I let it chill and modulate for another hour or so thinking that it may just be having a hard time figuring out the new hardware as i did have a decent overclock on AND had to do *another* clean install of Windows 11 this morning.
Long story short that obviously didn't help so i started troubleshooting. I got to the DIMMS and put one stick in Channel A, slot 2 (A2) Not boot. Cycled through all four sticks with the same result. Then I switched over to Channel B slot 2 (B2) and it lit up like a Like ignition from a rocket launch. Tried all the rest of the sticks, they worked. Tried both slots in Channel B, both would take. But, in Channel A if either slot is being utilized at all it won't boot. Again it'll try aggressively to get it to boot (as this is stock, default settings) but doesn't get through. Any thoughts?
Setup is:
Thanks in advance!
Setup is:
- MSI Z690 Edge Wifi DDR4
- 12900k
- GSkill Trident Z Neo XMP 4000, 16gb x4 - F4-4000C18D-32GTZN
- Just installed Artic Cooler Freezer ii
- Zotac Nvidia GTX 1070 AMP
- Nvidia P1000 x2
- x2 HDD's
- x3 NVMe M2's
- Be Quiet! Dark Base 700
- Like nine fans
Thanks in advance!
