Digi@nywhere A/D Not playing well with Vista Media Center
jasbur
I just got this card - it would have been nice if this limitation was documented somewhere by MSI!
Truth is, I don't even care that it won't support analog. I wanted to use it for QAM, but Media Center only sees it as ATSC.
Anybody have any ideas?
Which card did you buy?
http://eu.msi.com/index.php?func=searchresult&keywords=digital%40nywhere
I think you bought the wrong type of tuner. The Digital@nywhere card's ATSC tuner is only for 'over-the'air' digital reception, ie through an aerial/antenna, not through cable.
As far as I am aware, MSI does not make any TV tuner suitable for receiving QAM digital cable signals.
Sorry. I couldn't remember if I actually scanned so wanted to get home and try.
I get to the point where is says "scanning for digital antenna signal" for a few minutes, then it says "A TV signal was not detected."
It's plugged into my Comcast cable for QAM, but I never get the option to select what type of tuner I have or want to use.
It seems from your last comment it's set for antenna and not cable ("...where is says "scanning for digital antenna signal" for a few minutes,...")input. There has to be somewhere you can change the setting to cable input from antenna that it's obviously set at now.
