Disassembly/assembly guide for GT740 (MS-1727)
Stu
GENERAL OF THE ARMY
https://forum-en.msi.com/moderator/assembly-guides/assemble-1727.pdf
https://forum-en.msi.com/moderator/assembly-guides/ms-1727-disassemble-sop.pdf
Should also cover the GX740 model also, as the only difference I can tell from the spec is a different discrete GPU card. Also for E7405. All three models use the same base chassis (MS-1727).
