Display detection issue MPG 341CQR QD-OLED X36
anthonyhgaming
Hello, I have a Vector 16 HX AI A2XW laptop. I bought an MPG 341CQR QD-OLED X36 monitor. I am experiencing display detection issues. When I turn on the laptop with the monitor connected via USB-C to USB-C, both my laptop's built-in screen and the external monitor remain black. No signal is detected. I have to unplug and replug the cables several times. Both my graphics card and drivers are up to date. I do not understand the cause of this issue. Do you have a solution? My laptop is in discrete graphics mode, but it seemed to work fine at first. Lately, it has been impossible to get the external display to work. Could you please help me find a solution? Thank you.
Could you please check whether you have a USB-C to USB-C cable that supports DP Alt Mode? If so, it can enable certain USB-C ports to transmit video signals to an external monitor using the DisplayPort protocol. Please check the cable first. If the current cable does not support DP Alt Mode, please replace it with one that does and make sure it supports DP Alt Mode.
Yes, I did purchase a compatible USB-C cable specifically for this purpose. The problem also occurs when using the HDMI cable that came with the monitor. I’ve tried many different things, but nothing has worked so far. I have a PS5 connected to the monitor via HDMI, and there are absolutely no issues with it — the monitor detects the console immediately.
