Display Driver Nvlddmkm Stopped Responding and Has Successfully Recovered
hchg
Active member
LIEUTENANT COLONEL
Run DDU to uninstall the original NV VGA driver and start by installing the graphics driver version that's released on MSI's site that's for your model.
Make sure that you have your system up to date as well since sometimes the fail might come from the system's communication between graphics driver and the WDDM.
another problem msi gf75 thin 10UEK
Display driver igfx stopped responding and has successfully recovered ????
why every random black screen igfx and nvlddmkm???
Crazydonkey
SECOND LIEUTENANT
Have you tried to restore the system to default factory settings?
If the problem still remains, then the problem should be more related to hardware issue.
Bring the laptop to the nearest service center for a further check.
next3r
MAJOR
+ DDU for reinstall
create restore point ,.,.not use OC offset for GPU / or random undervolt for CPU domains
try EC reset
EC - fully shutdown ,.,.no AC .,,.small hole on back-cover "30s"
after this add AC "wait" 5min ,..,run system
+ DDU for reinstall
try EC reset
i have latest all drivers nvidia and intel
i have try ec reset ok i will test PC
im from Tunisia i bough CDiscount from France
how i can nearest service center bring back to France ? im still warranty 2 years
replace motherboard for free ?
Tell me
SATA mode selection
AHCI or Intel RST premium with Intel Optane System Acceleration?
I use always Intel RST premium
Maybe issue gpu?
Hi! Please try to delete and clean install the graphic drivers by following the instruction in the pdf below. Please help us look for the model name of your device. After that please insert your model name into the search bar from this website (https://www.msi.com/search/GF75 Thin ) and download the AMD driver under “Drivers.” Learn how to clean install AMD driver from this link: (https://us.msi.com/faq/3725)
Thank you for your understandings.
i have already try 1000 times drivers all original support msi drivers and still same problems i think hardware fault i have send msi in france for repair center
