Displayports on Radeon RX 5500 XT MECH 8G OC
wtkoos
This card has an HDMI port one one side and 3 DP ports next to it. But which one is DP1? The one next to the HDMI port or would that be DP 3?
And how to I 'activate' the DP ports because right now, none of them sends a signal to the monitors.
It is irrelevant which dp port to use and you can't activate them. Just connecting is enough.
What are you trying to connect?
