Does MSI MPG X570 Gaming Plus AMD ATX motherboard supports EVM 512GB 2.5Inch Sata Internal SSD 550MBs..???
Joyjit Nath
I use MSI MPG X570 Gaming Plus AMD ATX motherboard. Does MSI MPG X570 Gaming Plus AMD ATX motherboard supports EVM 512GB 2.5Inch Sata Internal SSD 550MBs ...? Please help to find compatibility of latest SATA III Solid State Internal SSD 500gb, I need to increase SSD from 240GB to 512GB.
There is no need to check/find the compatibility, if it behaves like a SATA SSD, it will work on a SATA port.
But i would not recommend to get such a no-name SSD, and nowadays, instead of a SATA model, i would recommend an M.2 PCIe SSD. They don't seem to have an abundance of decent models on Amazon India, but something like this: https://www.amazon.in/KIOXIA-EXCERIA-NVMeTM-SSD-500GB/dp/B0C7Z5DYXF
Can I use both SATA SSD and NVMe™ Internal SSD together...???
Yes, no problem. I'm doing so on my own system. Several M.2 PCIe SSDs and SATA SSDs peacefully coexisting.
Sometimes they're called NVMe SSDs, but a PCIe SSD can only ever use the NVMe protocol, so in my opinion it's more correct to say M.2 PCIe SSD.
