Does USB C connection on back panel of MPG Z690 EDGE WIFI DDR4 provide Thunderbolt capability ?
rdc5615b702ef
I am asking for clarification if the USB C connection on back panel of MPG Z690 EDGE WIFI DDR4 provides Thunderbolt capability?
I note that there is a Thunderbolt header on the MPG Z690 EDGE WIFI DDR4 motherboard although a compatible Thunderbolt card is nearly impossible to find. Any suggestion on where to find a compatible card?
badboy2k
no it doesn't.
1x USB 3.2 Gen 2x2 20Gbps Type-C port on the back panel
its just a USB 3.2 Gen 2x2 Data port is all it can do
