DOEST ANYONE HOW TO APPLY DUAL MONITOR
fatedust
Survey Corps
FIRST LIEUTENANT
Have you tried another working DP cable? Also it's recommended to use DP to DP cable.
Can you try to connect your monitor via DP to other machine? Just to make sure that monitor DP port is working.
Is that latest BIOS 7B89v2H?
Oh should I need to change in BIOS? i tried dp to dp but it doesn't work. I will wait for your reply im getting nervous rn.
fatedust
Survey Corps
FIRST LIEUTENANT
Forgot to mention one thing, are you in OS or in BIOS?
In BIOS, it's normal that only one monitor will display.
fatedust
Survey Corps
FIRST LIEUTENANT
So DP cable is checked, monitor DP port checked, boot in OS checked.
If onboard DP port still cannot output display after installing onboard graphics driver, the onboard DP port might be faulty.
