Dragon center issue
medskh123
I appologize for the wrong output of my previous post
I downloaded the dragon center form this link to customize my clutch GM 30 mouse
https://www.msi.com/Landing/dragon-center-download
and when the install finishes i only get sdk files and there is no trace of the dragon center and then i tried older versions and none of them gave me the option of setting up my mouse ( one of them kept working in background and didnt work at all )
btw i have a medium spec asus laptop (X556UJ to be exact)
so what can i do to fix this issue because i really need to change some settings in the mouse
fatedust
FIRST LIEUTENANT
Hi medskh123,
I would suggest you use the >>removal tool<< which was provided by moderator to completely uninstall UI & SDK from your laptop, and then download Dragon Center v2.0.54.0 from the product page of your mouse >>here<< (Utility > Win10 64 > MSI Dragon Center)
After the installation is complete, unplug/plug your mouse and look for "Gaming Gear" or "MSI Device", you can change settings on your mouse there.
