Dragon center Mysic Light missing
sfkjn715ce02e6
The Mystic Light option is no longer appearing in Dragon Center. I have uninstalled the app with the MSI removal tool, rebooted and installed the latest version, still the mystic light is missing. Done this several times without success and don't know what else to do. Attached are some screen shots, if anyone has some useful tips on what else to try I'd appreciate it.
sfkjn715ce02e6
Thanks for the help, I uninstalled Dragon Center with the removal tool and installed MSI center. However, the only feature available is "system diagnosis". I'm at a loss why Mystic Light will still not appear even after removing and reinstalling MSI Center. PS: I noticed there are still two Dragon Center items showing up in task manager (see screenshot) which will not let me delete them. Even tried it with Ashampoo uninstaller. Could this be the problem?
zerijelly
FIRST LIEUTENANT
Could you set the two Dragon Center items to stop running in the Task Manager and check whether the features in MSI Center could show up correctly?
You could generate log file for debug with MSI Log Collect Tool.
sfkjn715ce02e6
Dragon center is no longer showing in task manager, somehow I was able to remove it. Un-and reinstalled MSI Center but it looked just like before, the only option there is again, system diagnosis but nothing else. I attached the tool log below.
Administrator
This appear to be some OEM board [MEDION]
I'm not sure if that app. is suppose to run in there.
In anyway check it with your OEM Vendor.
sfkjn715ce02e6
Dragon Center did work up until a year ago, then all of a sudden the Mystic Light option wasn't there anymore.
