S
skiZtch
Guest
I just bought a G4 Ti4200, and it has the VGA out and the DVIout with the converter and the box says DUAL VGA SUPPORT so i know it's possible with this card.
I went on the nVidia website and found in some online manual to check this option "treat other displays as separate outputs" or something in the Desktop Utilities tab in the additional GeForce 4 Ti4200 properties...etc.
Anyway, that whole option isn't there. There's just the "Display quicktweak" and "Enable Desktop Manager" boxes there. So, i'm a bit confused, and I just want to get separate displays going. Also if anyone knows how to do i anyother way, that'd be great. Cloneview does work, it's just getting windows to have a second display.
Thanks
Thanks
