Easy way to set up PBO + undervolt curve for better cooling?
robman501154002d7
Active member
I'm going to try this.
UPDATE:
And that crashed and rebooted right away as soon as I attempted to load Cinebench.
This works in FS2020 with the new power supply! :) Nice temps too! Thought of trying something a little more intense and wanted to see what would happen with -25 on all core. Nope! The system didn't like that at all and it rebooted.
robman501154002d7
Active member
Ryzen master
Or you can try the Curve Optimise App I have added it will do curve setting on the fly
Detail in this post
Your temps look ok to me your not maxing out so should be Ok
Cure Optimises should be good at -25 but you can also try -30 all core and see how it goes
Try setting shown in second pic
Since the system is stable now, I'm not too sure if a value of -25 would work for all cores, also should I try the boost override of 200 or would that damage the CPU and void the warranty? I think I have a 3 year protection plan on my CPU.
Alan J T
If your happy with it then leave it as is all boost over ride dose is improve single core performance a bit. Not really enough to notice in most cases perhaps one or two extra FPS in games on average
robman501154002d7
Active member
I'm happy with it at stock speeds and voltages but I find it preforms a little better with undervolting. ;) I think for my gaming, it might be more of a GPU thing anyway but for video rendering and compression utilities such as 7-Zip, the single core boost might improve things. 🤷‍♂️
robman501154002d7
Active member
On an unrelated matter regarding my DeepCool DA700 PSU and what you have in your signature ... I can vouch for this! $70 PSU or ~$200 PSU. 🤔 -> ;) Very happy with my decision to get a better model. :)
