Eclipse SLI CPU fan always on max
mibsen
Hello i got a problem with my Eclipse SLI. It's look like the CPU smart fan function don't work and the CPU fan is on max all the time.
My bios temp's goes from 32-40 C. I have used a lot of different bios versions. 1.4 - 1.7 - 1.9 - 1.a none of those could fix it.
Eclipse SLI
Intel i7 920 - standard clock
hope anyone got a good answer to my question. thx
They have a switch for "always maximum cooling" and "temperature controlled speed". Check your CPU fan - it may help to read the CPU installation instructions as they show where the switch is. I would guess that you have it in the wrong position, so your BIOS can't do anything...
Screet
I have tried 3 difference CPU cooler's now and 2 difference 4pin fan's none of them chancing anything. Is it something on the motherboard or in the bios i have to chance? I have tried chancing CPU fan speed in MSI OC-center nothing happened, I could chance fan speed for fan 1-2-3.
