I thought I'd cured this, but apparently not...
I'm running the system described in the sig, with this Corsair RAM. It claims to be i7 compatible and designed to run at 1.65V. The BIOS defaults to trying to run it at 1333MHz. This causes semi-predictable instability - the first boot it will bluescreen; it will then reboot and function perfectly. Sometimes it will only see two sticks, sometimes three. It seems to be similar to/the same as the problem here. I tried reducing the speed of the RAM to 1066MHz in the BIOS, which worked for a while, but this morning the machine refused to POST, and then subsequently reset the settings to defaults claiming that the "overclocking" had failed. This has restored the previous bluescreening problems.
Does this sound like a board problem, a RAM problem, a configuration problem, a problem that can be fixed with a fresh BIOS [currently running v.1.2; flash attempt whilst stable at 1066MHz failed due to non-bootable stick, and I don't want to try again until the machine is stable], or something else entirely?
Thanks for any help!
ETA: Here's some screenshots of CPU-Z.
