EFI stub: Warning: unable to unprotect memory range on boot
asd156202d5
I'm observing an error message on boot after upgrading my motherboard BIOS version (specs below), "EFI stub: Warning: unable to unprotect memory range on boot". Despite the error my operating system does appear to boot after this message, however I'm hoping for some clarification and if there is any remediation.
Specs:
Motherboard: MSI MPG X870E CARBON WIFI
Motherboard BIOS version: 7E49v1A7E
OS: Arch Linux x86_64
Kernel: Linux 6.18.5-arch1-1
CPU: AMD Ryzen 7 9800X3D
GPU: Nvidia GeForce RTX 5080
This problem has been reported for newer ASUS motherboard BIOS versions as well: https://bbs.archlinux.org/viewtopic.php?id=311516
Has anyone seen this recently and/or aware of a fix?
Thanks!
Unable to unprotect memory range on boot, sounds like it does a good job with the security protocol.
Do you find any problem other than the message though?
No other issues that I can tell, and journalctl and dmesg logs seem fine.
You allude to a security protocol, could you elaborate for me? Probably worth mentioning that secure boot is disabled in the BIOS, so I'm unsure if that's related. However googling searching around seems to indicate it might.
Specs:
Thanks!
The issue is duplicated.
MSI Team is investigating the issue, please be patient.
Thanks.
I will update this topic when there is a news and update about it.
Specs:
Thanks!
This is also happening on the mai mag b850 tomahawk wifi
Running cachyos latest build and latest bios
Hi @Svet , Im just curious if there has been update on this? My internal ticket was also closed with no additional information, yet I do see a new BIOS version for my particular motherboard. Do you know know if 7E49v1A8 patches the behavior reported?
From emails they are still looking into it at this time
Please wait patiently, MSI is checking with AMI.
If you have any other issue than the error message reported,
then tell full details about it.
Will the same fix be applied to other motherboard models too? I have this same warning on a MAG B850 TOMAHAWK MAX WIFI and wonder if the first line I see below is the exact same problem and whether or not I need to make a separate thread for my board
Probably, if the same issue exist there too.
If the issue is the same is OK to be here.
Will check if such BIOS update is planed (or already exist) and will update you.
Hi, same thing here after I updated BIOS of my B650 Gaming Plus Wifi to 7E26v1M. I suppose this is related to AGESA PI pre-1.3.0.0 update, since this did not happen with M beta releases (using AGESA PI 1.2.0.3). I am using Archlinux and do not see any issue.
It will be fixed with future BIOS updates,
check the new updates at web page when they are released and have a try it.
Same as above probably will be fixed for your board model too with future BIOS updates.
Thank you for the quick update. I will keep an eye out for a new version and report back after updating.
Updated my MAG B850 TOMAHAWK MAX WIFI to the newest version (7E62v2A53 2026-03-20) today and after rebooting the second line is no longer there, but the first one remains:
No EFI_MEMORY_ATTRIBUTE_PROTOCOL found, skipping NX_COMPAT support.
Is this "NX_COMPAT support" something that can/will be fixed by future updates? According to https://github.com/systemd/systemd/pull/38678 the warning is logged because the firmware should support "EFI_MEMORY_ATTRIBUTE_PROTOCOL" but doesn't?
Not a big deal and the system still works, but the warning sticks out like a sore thumb in my otherwise silent boot setup. That said, I am grateful for the support given even if Linux is not an officially supported OS.
