charonme
- Nov 4, 2023
I'm trying to draw a performance/power limits curve for my 14700K, setting progressively lower power limits and doing a short 4minute CB R23 run to get the score at each power limit with LLC4, AC/DC 18/32, CEP on, -0.1V offset. I thought I already picked a high enough AC_LL not to trigger CEP clock stretching, but around PL1=PL2=190W I noticed a slight dip in the scores. So I checked if it was caused by CEP and turned CEP off and sure enough even at AC=18 LLC4 CEP was still kicking in at PL=190W (but not at different power limits around that). So I tried some other higher AC values and adjusted the offset accordingly.
Now I'm trying AC/DC 52/32 and -0.145V offset. So far from PL=270W down to PL=160W I got a smooth curve of decreasing CB R23 scores, but at 150W and 140W it suddenly dipped sharply from the curve. So again I checked if it's CEP and turned CEP off and tried again, but this time I got 1151 FEWER points with CEP off. Also the average P-core frequencies were 164MHz smaller, average vcore around 13mV higher and temperatures also slightly higher with CEP off. I switched CEP on and off back and forth a couple of times and measured the scores to ensure it's not some fluke, but it's quite consistent. At these settings I really get better performance with CEP turned on. I also tried some other higher power limits with and without CEP and those are also better with CEP. What's going on? I thought CEP could only cause worse performance. (Also there is still that lesser mystery of the dipping score below 160W)
