External NVME drive connected via USB are not readable
jelliott062760
When attempting to add an external NVME drive via USB port, the drives are not accessible. Note: several different NVME drives, USB cables and enclosures were used.
Not much information to go on here.
I'll go out on a limb and say that when you say "not accessible", that the several different NVMe drives do not show up in Window 11 File Explorer.
Could be you need to use Disk Management and assign an available drive letter to the NVMe.
Correct. Disk management will not allow to format. reads drives as 0 bytes
Just deal with only one of your NVMe drives.
The hardware device that has the USB connection for the NVMe works properly in a different computer or has worked before in your MSI pre-built desktop?
Do you want to format the NVMe drive thereby erasing all data from the drive? Because there are ways to format the drive outside of Disk Management.
So the NVMe drive at least shows up in Disk Mangement. Then it has a "Status" and other properties. A screenshot or report from you will be very helpful.
Drives may be locked. Getting the same result with different M.2 drives and enclosures suggests a security lockout or Fake M.2
Are they new M.2 drives, or have you been using them in the past?
SO many Scam and Fake M.2 drives are on the market now.
Buying from any where not a legitimate supplier is risky
The drive in question is a WD nvme 1tb. It worked fine on an older Desktop with win 11 as did the 2 different USB enclosures used and two different USB cables
