fan adapter unconnected
  • Thread starter Thread starter rpckvv
  • Start date Start date
R
rpckvv
Guest
i received my msi geforce4 ti4400 a couple of days ago and was shocked to find that the 2 pin fan adapter was completely unsoldered when i took it out of the static bag...ie- i tried to simply disconnect the fan from the board, but instead, i was able to take out the whole adapter (receiver, whatever)...
this left me with two holes in the board, and i am wondering if this should prevent the computer from booting (ie- posting)...
i placed the ti4400 in my old computer (i'm building a new one and am not able to discern exactly which component is not working with that one), and the computer refused to post...
would this have to do with the lapse in quality control regarding the stock fan (ie- does current have to flow through the two "holes" where the fan adapter used to be in order for the whole card to function?)
if you still dont understand what's up, here's a pic to help:
the white connecter (THE WHOLE THING, WITH THE FAN STILL ATTACHED) comes out...what i mean by this is that the pins that come out on the back of the board are not soldered on...like if one of the capacitors werent soldered on...i can just pull it out!!!
i'm not really planning on using the stock cooler anyway, because i have a 1U HSF that i wish to put on the gpu...
help would be greatly appreciated
-peter
I would use the warenty and replace the card since this might just be one problem in the sodering that you can see, you have no idea what else went wrong with this card that you can't see.
It is obviosly a defective card, replace it while it is new!
