Fan curve control cc
vomesk
Hi!
I have a new Prestige 15, i'm happy with it but i have a problem that's driving me crazy. The fans are always working even in idle and it's a bit anoying, the only way to stop them is choosing the super battery mode in creator center but then the laptop is working at minimun power. There ir a way to create a fan curve control in balance mode for example or something like that?
Thanks and happy new year.
Crazydonkey
SECOND LIEUTENANT
If you are using Creator center 1.2, uninstall the program, and delete Creator Center folder under C:\Programs Files x86\MSI.
Reinstall the UWP version from MSI website.
Then, you can set the user scenario to High Performance, and set the fan mode to "Advanced" to customized the fan speed profile.
vomesk
Creator Center is not working anymore on my prestige, it says Download Drangon Center from MS Store, i did it but Dragon Center has no options availablesl, just color theme.
