fan for msi ge70 2OE
tojestklasy159502e6
Hi my fan for MSI GE70 2OE broke, I've bought like 3 diffrent ones from ebay and they don't seem to work. They spin for like 3 seconds and they stop. I've called MSI but they don't have those parts anymore.
I've been advised to look for E33-0800413-MC2 but every single one I've ordered so far doesn't seem to work. I even found exactly same one that I had PAAD06015SL N285 but the issue is the same. Can anyone give advise or any help with and issue? It's a shame because everything in that nootbook works flawlessly so far, beside that fan. I've tried to replace black fan from newer one but the head is too worn out and it wooble against casign.
Edit: S/N GE70 2OE-014NEK1307000150
nysmeee155102da
Active member
How did you confirm the original fan was broken?
I suggest you change back to the original fan.
Update the EC firmware to the latest version and perform EC reset by following this guide (it's different from EC update).
After that, check the situation again.
After reading your situation, I think this is not a fan problem. It's a problem elsewhere. You need to find the right problem to really solve the computer problem. You should confirm in detail before buying.
tojestklasy159502e6
Hi, I've bought orignal fan and It seems to work fine. New problem is notebook seems to overheat a lot. I guess part of the problem is MSI decided to give one fan for i7 and geforce 765m to cool it down, but if anyone has some ideas how can i solve heating problem, please share.
nysmeee155102da
Active member
What temperature you see?
And you mean CPU or GPU temp?
And what you did when you saw the laptop overheated? During games?
