Fan not working after EC update
aksoyozca150e02d4
you can re install the fully working old EC over it.
may be the new EC is not compatible with some of the setting and this always could happen when new EC issued.
Reverse back to older version and wait for another update of EC and try again.
how to access to older version EC, pls check on MSI forums or Google it.
Do you follow the instruction to perform a EC reset?
It will re-detect the hardware component.
If you try to enable "Cooler boost" from MSI Center [rp, can you see the fan start spinning?
