msili8150202d2
- May 20, 2022
I'm new to MSI Center. I find fan speeds displayed as RPM less helpful than percentage readings would be. Is there any way of adding percentage readings?
It's the list of system fans on the right side that I'd prefer to be shown as %Need to specify as CPU is in both so you want Sys fans as % to or what.
Also, My display is different from yours. It does not show the CPU fan on the left only CPU Temp and CPU usage. Is there a setting to match yours?Need to specify as CPU is in both so you want Sys fans as % to or what.
For now yes but it may be added in future updates. But it is also a broken app for quite a few users. So current bugs would need to be repaired before adding extra functionThanks.
So it looks as if I'm stuck with no %'s
