Firmware update MAG274QRF-QD
dannis215b402ea
Having this problem as well, running the latest firmware. Can we get a fix for this in Win11 please, MSI?
Very annoying having it disconnect swapping sound devices etc.
I had this problem as well - the screen would turn off after 10 mins as per my Windows 10 power settings, but it would prevent the computer from sleeping because it kept playing the device disconnect/connected Windows sound. I unplugged the USB from the monitor and it still happened so I unplugged the DisplayPort cable and then it stopped making that sound.
In any case, I fixed it by making sure Auto Scan was disabled and the Power Button setting was set to Standby and not Off. I thought I had already set those settings via the monitor's GUI (not GamingOSD) but I think they didn't persist. I changed the monitor's settings and tested it by setting the Windows screen turn off after 2 minutes, which it did as usual, but I didn't hear the annoying device connect sounds! Yay! We'll see if it sticks...
HELP!!!!!!!!! I just updated through the gaming osd and after the update it told me to plug back in the ac adapter. It was never unplugged and now when it boots I get the logo for 1 sec and then it shuts off. FW is 037 released on 05-10-2022.
make a new thread if you want to be seen. if not it's going to get buried here with the problem of the OP which is similar but not the same.
Hello i have the MAG274QRF. I was updating the last FW and my monitor turn off like dont have energy. Now doesnt start, no lights, no power on signals. Some have idea what i can do??
kunlea1156c02e5
Hi
any luck with this.. Just got mine like an hour ago.. First thing i did was the update on display port.. It complete 100% and after pluggibg ac back in monitor just flashes msi logo and goes off
njlitz9158602e1
Hi, Any update? I just bought " MAG274QRF QD" today and I was check-in to see if it brings anything if I update the FW. It comes with FW v 019 I think. I checked MSI website and there is no fw to download there!
Same here, just got it today and went to get the latest firmware - nothing listed to download! I bought a refurbished unit from Woot, which is running FW.014
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
contact MSI support and ask them for the FW file
