- Nov 13, 2015
There had been recent report regarding firmware update failure with the progress bar stuck at 1% and not moving further.
Try below workaround to fix/bypass the problem,
1. Unplug-replug monitor AC power
2. Find and temporarily disable Dynamic Lighting device in Device Manager,
4. After monitor firmware update completes, enable the HID-compliant device again in Device Manager
This workaround only works for stuck 1% scenario. If you have firmware update problem with different symptom, it will not help.
Location: Human Interface Devices > HID-compliant device > Details > Hardware ID = VID_1462&PID_3FA4&MI_01
3. Proceed with firmware update4. After monitor firmware update completes, enable the HID-compliant device again in Device Manager
