S statoman8153002de New member Joined Oct 14, 2020 Messages 15 Oct 16, 2020 #1 Ok I have the B450M PRO-M2 MAX so when overclocking why does the speed set by the multiplyer not throttle down when there is no load?
Alan J T GRUMPY OLD FART Joined Sep 11, 2020 Messages 2,156 Nov 1, 2020 #2 It is the way it works it seems the Multiplier is locked on manual OC but as there is no load when idle there should not be a problem a problem.
twinshadows404 New member PRIVATE FIRST CLASS Joined Sep 18, 2019 Messages 11 Nov 27, 2020 #3 Changing the multiplier turns "Cool 'n' Quiet" off. You should re-enable it after you're done overclocking.
