First time builder needs help
vanmo157c02db
Hi, this is my tale of woe. I am working with MSI MB MEG x750 ATX. All of the enclosed connection wiring is completely different from my 10 year old SMILODON case which puts it out of my league. I seem to have just 2 options, pay local shop $200 to change the wiring and do the parts installation OR can I buy an MSI case (MPG GUNGNIR 100) which will be wired to accommodate my MSI MB? Hope my explanation is clear. Frank
Active member
What MEG x750 do you mean? Any MEG X570 board? If so which one excatly?
bil15b802e6
Probably doesn't matter which of the two X570 MEG boards you're using, they are both ATX. So, I have to ask the question, why not just get a new case if you don't think the old one will accommodate the new gear? That seems like a simple solution.
