Fix for GTX970/980 Fans Randomly Turning On issue
Status
Not open for further replies.
GENERAL OF THE ARMY
The much discussed issue with fans of GTX 970 GAMING 4G randomly starting to run in idle (https://forum-en.msi.com/index.php?topic=184333.50) seems to be fixed with a vbios update. To point this out: These are official MSI files and no vbios mods
A very big thanks goes out to the German MSI forum and their moderator wiesel201 who pointed me to >>his thread<< and the files on the German forum.
To get started you first need to identify the correct vbios for your card. Therefor you need to check the card's S/N.
Example of a GTX 970 GAMING 4G's S/N: 602-V316-03SB1409025XXX
The number code marked red representing the card's batch is relevant for identifying the correct vbios. The table below shows which vbios applies to which batch number.
If you are unsure which one to use always ask one of the moderators or admins instead of hoping for the best!
09S / 03S / 010 NV316MH.182 -> to download NV316MH_182.rar
10S / 04S / 020 NV316MH.191 -> to download NV316MH_191.rar
11S / 05S / 030 NV316MH.1A1 -> to download NV316MH_1A1.rar
For our example card with the S/N 602-V316-03SB1409025XXX NV316MH.182 is the correct vbios so NV316MH_182.rar needs to be downloaded.
After downloading the matching archive first uninstall the Nvidia driver (!) then simply decompress the archive and then execute the included batch file (182.bat in case of NV316MH.182's archive) in Windows by double clicking or via command prompt (must be run as administrator)
wiesel201 in http://forum-de.msi.com/index.php?page=Thread&threadID=107032 said:
Same like above now also applies to the GTX980 Gaming series:
03s / 13s  NV317MH.112 -> to download NV317MH_112.rar
06s / 14s  NV317MH.131 -> to download NV317MH_131.rar
11s / 15s  NV317MH.143 -> to download NV317MH_143.rar
12s / 16s  NV317MH.153 -> to download NV317MH_153.rar
Thanks again wiesel201!
*Please note that this just covers the issue with the fans randomly starting and not the problem of one fan not starting at all on earlier cards which is a defect that requires rma.*
  • NV316MH_182.rar
  • NV316MH_191.rar
  • NV316MH_1A1.rar
  • NV317MH_112.rar
  • NV317MH_131.rar
  • NV317MH_143.rar
  • NV317MH_153.rar
I'm starting to run out of ideas here
MSI GeForce GTX 980 Gaming 4G, had the usual issues with 2nd fan spinning for no reason
Fixed it first time by just shutting down computer
2nd time I needed to reinstall drivers, shutting down didn't work
3rd time I needed to update vBIOS, reinstalling drivers and shutting down didn't work
Now it's doing it again, 4th time (I've only had this card for short'ish period of time)
I'm already on latest vBIOS, so can't really upgrade that, tried shutting down, re-seating the card, reinstalling drivers, no luck.
Only thing I haven't tried is just flashing the same newest vBIOS again and hope it fixes the issue, but it seriously isn't an option that I go and flash the vBIOS every time the card decides to act up like this.
I think this time it started after the computer went to sleep, and woke up - or at least I was greeted by Windows 10 log in screen in the morning when it was spinning again.
Win10 x64, GeForce 359.06 drivers, MSI Afterburner is installed and obviously can't see the 2nd fan
Losing my mind over this, I really wouldn't want to block the fan completely to make it stop
I have GTX 970 GAMING 4G with serial 602-V316-03SB1411007063
OS WIN 8.1 64 bit.
One of the fans randomly starts (i think it need some 3d app is running, though). It seems that it working with 100% power (very loud) and never stops once started. Only turning off/on computer helps.
I've tested my video card with furmark and fans worked well, rising/lowering speed accordingly gpu temperature
When random start happened in almost idle state (may be some light nondemanding 3d app is running)  - all test programs shows fan speed = 0, but in reality , speed, of course, is very high
What should i do to resolve this problem?
That is not the issue of this thread that is about an earlier vbios issue starting both fans randomly. Only one fan starting at 100% on a 970 Gaming is in 90% of cases a hardware defect that requires rma. I already stated that in the initial post of this thread:
To be sure open your own thread where you provide the card's S/N and a copy of the current vbios.
Hello! so i bought the MSI GeForce GTX 970 4G and got the same issue with the fans.
My S/N is 602-V316-440B1601003001
Which file do i need to use?
Thanks a lot for an answer!
~ alex
Your card is too new to be affected by the issue this thread is about. Your card is from January 2016. The issue has been fixed in 2014. Open your own thread with a detailed description of the issue, the S/N and a copy of the current vbios.
SERIAL 602-V316-050B1412021058
[pre]NEED THIS STOCK LAST PLATE BIOS , I DO NOT HAVE SUPPORTING THE ORIGINAL AND I'M RUNNING WITH A MODIFIED PROBLEMS BIOS GIVING THANKS
IM NEED VBIOS NV316MH.186
svet have trouble vbios flash, which can habrir a new thread , it is as if the estubiera vbios locked, have installed a modified bios will not let me return to factory settings which is not the problem
tiolucasss, this thread is not for general troubleshooting or vbios requests. Open your own please.
No, you don't have this exact problem. 980ti was never affected. You have any other problem. Please open your own thread for it.
Hello
I hope someone can advise me
I have a GTX 970 4D
serial 602-V316-130B and I'm not sure which bios i should use
my problem currently is that i did not change anything in my computer but whenever i run a game the computer reboots.
i've tried fresh install same thing :/
i tried with internal GPU there so far no crash but of course game is unplayable ^^
thx in advance
This issue does not affect the 1060 it is an issue related to very early GTX 980/970 vbios versions that is the only subject of this thread. Open your own thread please if you have an own issue.
Status
