so, 2 things.
First:
I noticed that on the MSI BIOS website, the MSI x58 Pro and the MSI x58 Pro SLI mobos have remarkably similar specs, with the exception being the sli version have support for both xfire and sli. I then checked the BIOS, and this is what I found:
MSI Pro:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1744
AMI BIOS 7.1 808KB
2009-02-18
file: 7522v71.zip
MSI Pro SLI:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1745
AMI BIOS 8.1 807KB (It's smaller by 1KB :O)
2009-03-10
file: 7522v81.zip
Anyway, looking at these 2 files, it seems that one should be able to flash the pro with the pro sli BIOS. Perhaps you guys heard about Gigabyte's board having SLI built in, just locked up and unavaiable until some dude flashed the board with a sli compatible bios and got it working. While I doubt such is true of the MSI Pro board, I do think that the two would be similar enough that the pro sli bios would run on the pro. Perhaps it will help me with the IOH heat problem on the pro, which leads to my second problem...
My Pro mobo runs v7.1 BIOS. When I checked the temperatures, the IOH seems to be idling at 87C. The computer runs fine, but I'm a bit worried since the critical temperature is 100C, and 87C is cutting it close. After reading the forums, I cleaned the surfaces of the heatsink and the chips and changed the thermal paste, and now it ranges between 80-87C. I'm thinking about giving the thermal paste 3-4 days to cure, and hopefully it stabilize and drop to a decent range. Now I am wondering if flashing my BIOS to the Pro SLI version 7522v8.1 would help at all.
any suggestions/comments?
First:
MSI Pro:
AMI BIOS 7.1 808KB
2009-02-18
file: 7522v71.zip
MSI Pro SLI:
2009-03-10
file: 7522v81.zip
